The tub appears to be rubbing against somethi behind the rubber seal.
Makes loud noise when spinning even though the machine is level. I'm finding slivers of some sort of plastic, or fiberglass material in the tub after the cycle is over with. It appears there is a ring of this material around the outside of the tub that can be seen when you pull the rubber seal to the side. Any answers?
Es esta una buena pregunta?
