Saltar al contenido principal
Esta cámara instantánea de Fujifilm ahora cuenta con un cuerpo más delgado y liviano que las revisiones anteriores. El Mini 8 ayuda al fotógrafo alertándoles sobre la apertura recomendada. También tiene un modo de flash High-Key que ayuda al fotógrafo a obtener retratos suaves para una apariencia deslumbrante.
Preguntas 355 Ver todo
setting light is stuck on house icon picture.
I droped my camera ..but it still works fine except the seetings light is stuck on the home picture ( icon) and when i turn the arrow towards the diffrent setting nothing happpens...how can i fix it ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
hey so after I saw your message (cause the same thing just happened to me and my camera is brand new and hasnt taken any fall) i decited to try something. I took it outside when it was supper sunny and turned it on to se what would happen. turns out the camera is smart enough to detect what setting you need. by being outside in the bright sun it turned the setting light on very sunny. then i turned so it had a slight shadow of my body and it switched the light to sunny. then i casted more shadow on it and it turned to cloudy and as u can figure it out when i covered the sensor fully it turned to house. so if you have only noticed this while inside the house, take it out on the sun and see if it changes. then your all good and its a camera feature that suggests which setting u should use lol Hope this helped! (;
Fue útil esta respuesta?
Puntuación 1
1 comentario:
i tried that last christmas and it was like that ever since i opened it but it wont work... :(
- de
My insta is stuck in tht house what should I do nw ?
Puntuación 1
i have tried every method on this website and it’s still stuck!
Puntuación 0
1 comentario:
The light is always on the home icon and it won't switch to other settings when I go outside, I trusted the camera's choice of setting(home) and took a photo outside where it was bright, sadly the photo turned out black with some lights(reflected from car number plates) Please suggest a way to fix this problem.(the camera is pretty new and it's Instax mini 9)
- de
Añadir tu respuesta
ivyana estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 35
Ultimos 30 días: 110
Todo El Tiempo: 15,445
