Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
wifi greyed out and bluetooth keeps spinning
My iphone 6 wifi greyed out and bluetooth keeps spinning, wasting valuable data, everything else works, I recently replace my digitizer and glass and now this. I reset everthing, rebooted phone to original from itunes, maybe I left something loose, any suggestions or help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
That means the wifi/Bluetooth flex has been damaged and needs replaced. I would replace it after factory resetting your phone first.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
If Wi-Fi is greyed out (can't turn on) it is more likely a board issue (could be software but unlikely). Usually the Wi-Fi ic chip going bad.
- de
I have the exact same problem, just got the flex ribbon, and am attempting to replace now. Wish me luck. Question, how can you tell if the antenna also needs to be replaced? I would rather not crack this open twice.
Puntuación 0
Did anyone have Luck With this I have an iPhone 6 With the same Problem
Puntuación 0
Añadir tu respuesta
wayne estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,411
