Saltar al contenido principal
Manuales de reparación y soporte para automóviles y camiones fabricados por Chevrolet, una división de General Motors.
Preguntas 1371 Ver todo
Carb is throwing gas and wont Idle
1976 Monte Carlo
My Monte is in the garage for the winter and I like to start it from time to time Just to keep the oil moving while its sitting . Today when I started it it chocked and puked a few times and ran with help on the throttle but wouldn't idle just puked a out a lot of gas . It has s 650 holly double pumper . Any Ideas as to whats going on.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Try taping the float bowel till the pins let loose and the floats re-float. This happens when you don't put stabilizer in your fuel and your engine sits for extended periods. The ethanol in the fuel causes a green sludge build up in the carb that makes the float pins stick . give the float bowels a tap with hammer not hard you just want to free them up . you may want to pull that pumper apart an clean the jets and needles and the float bowl reservoir. Hope this helps
Fue útil esta respuesta?
Puntuación 5
1 comentario:
Tap trick worked and I decided to put a carb kit on it so i cleaned it out and you were right about the green scale. I'll have to remember to use a fuel stabilizer after this.
- de
Añadir tu respuesta
Robert Unclair estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 86
