2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Preguntas 224 Ver todo
A1398 Late 2013/Mid2014 MacBook Pro... No LCD Display
Hi all,
We had a cracked LCD on this model but still had 80-90% working display on the screen. We replaced the LCD, and screen was completely black. Assumed it was defective, so we ordered a replacement and installed.. and again no display.
We tested the HDMI display and got a perfect signal... computer is working great.
I can believe that we received two defective LCD's in a row, but I find this highly unlikely. Any other ideas?
TYIA
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
I too was presented with a broken screen so immediately went to swap it. Followed all the correct procedures, second screen has faint image but no backlight.
Reinstalled the cracked screen and it works fine(minus the crack) so it's not the backlight on the Mobo.
Is there any way to repair/check the second screen backlight?
MacBook Pro "Core i7" 2.2 15" Mid-2014 (IG) 2.2 GHz Core i7 (I7-4770HQ) A1398
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Best advise here is to order the correct part.
Fue útil esta respuesta?
Calificación 3
Esta respuesta fue originalmente para otra pregunta .
My father had the same problem with his Macbook Pro. I fixed it just by turning it on and letting him typ in his password. I believe after that it just fixed itself (it's been a while since it happened). Maybe try changing the brightness of the screen after logging in. I don't know if this will work for your clients Macbook but I hope it does.
Calificación 0
Comentarios:
Unfortunately this isn't doing it. We tried that. Thank you for the suggestion.
The real question here is will a 2013/2014 LCD work on a 2015 model
por
Did you find out?
por
Añadir tu respuesta
KB24 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 11
Todo El Tiempo: 568
