Secret Code for Display Test
Hello there,
can anyone help me?? Dis Apple had a secret code like Samsung (*#0*#) ??
Es esta una buena pregunta?
Hello there,
Nope there is no secret code to test the display.
You can use an app to test the screen however.
Fue útil esta respuesta?
Apple iphone secret code please
@ikhlaq there is no secret code!
yes their is
I have seen this code used. And it worked. *#21#
You can check your screen either the panel is replaced or not by comparing your iphone to another which you think is genuine.
How do I test my screen because it’s not working properly i11 pro max
Hello: No secret code. However, the link to the APP for a screen test is in the iTunes store. As of August 23rd, 2017 you have Version 4.0.
https://itunes.apple.com/us/app/touchscr...
You can test the pixels, touch, pinch, move, multi-touch on 6s and beyond.
Remember, aftermarket replacement screens DO NOT provide the moisture seals, response, and drop performance so please use Apple Care or a Certified replacement brand such as eVero. Your iPhone is worth it.
Enjoy, have fun.
Apple uses a special factory firmware called SwitchBoard to perform factory calibrations. It is NOT possible to install it without factory or service center tools, so there is no code to stare test mode because it is likely never there on retail devices in the field.
Apple iPhone secret codes
Ultimas 24 horas: 23
Ultimos 7 días: 216
Ultimos 30 días: 938
Todo El Tiempo: 246,037
1 comentario
No it doesn't, because it's a cheap made chinese brand with 60Hz display and 3200mAh and times are rough, we can't add a fast charger of ...drumroll 18 Watts ...because we are saving the planet..
Whilst soldering ram, ssd for the past 5 years...and making flimsy too short backlight cables in 400€+ laptop panels and butterfly keyboards that stick like butter.
Running the company as a beancounter gets you trillions!
Bless c.r.Apple! :)
- de TB_rep
