Saltar al contenido principal
Esta cámara instantánea de Fujifilm ahora cuenta con un cuerpo más delgado y liviano que las revisiones anteriores. El Mini 8 ayuda al fotógrafo alertándoles sobre la apertura recomendada. También tiene un modo de flash High-Key que ayuda al fotógrafo a obtener retratos suaves para una apariencia deslumbrante.
Preguntas 355 Ver todo
Four pieces came off the camera when it fell off the shelf...
4 pieces came off - the round plastic piece around the lens, some bracket under that and I think the 2 shutters that go over the lens.....how do we put these back on? it looks like it should be simple?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 11
15 comentarios
My close up lense won't fit into my camera and the first time I tried it, it worked fine, but I took it out and now doesn't fit.
- de
what happen if one of the holes are broken
- de
I don't remember dropping mine at all but when I went to use it the black part around the view finder was completely gone!!! I just got it, and I can't find where I can order the missing peice!!!! Can anyone help me???
- de
Hi Ash, as I mentioned on the previous post, I 3D modeled that part. Despite that I haven't test it yet (a friend just printed it and it is on its way) I could send you the file if that would help you. Let me know!
- de
My 2 year old broke this off and i think i throw out one of the yin/yang pieces not knowing what it was from!. Not sure.... and i cant find it either.... can you send the file to me as well?
- de
Mostrar 10 comentarios más
Agregar un comentario
5 Respuestas
Respuesta Más Útil
I just had the same thing happen, and I think I fixed it! The two little black pieces cover the lens when not in use. There are little holes at 12:00 and 6:00 (as if you are looking at a clock). The little black pieces have notches that fit in the holes, and the two pieces fit together like puzzle pieces (almost like a yin/yang symbol). The larger black piece that is more square sort of snaps in over top of those. There are guide holes. Then the lens part snaps back on. You might have to fiddle with it to get those two small pieces to fit, but it should work. Good luck!
Fue útil esta respuesta?
Puntuación 27
24 comentarios:
Thank you, I dropped my daughter's camera and your post help a lot.
- de
Sorry, I cannot get the square part to fit, can you hel me??
- de
Is there anywhere I can buy new lens covers? Mine broke
- de
thank you sooooo much!!! this helped A LOT!!!!!!!!
- de
Thank you! i just hit my friends camera out of their hand when i went in for a hug--this saved me $100 and my testies
- de
Mostrar 19 comentarios más
Find the attached videos to fix this
Update (08/14/2021)
. Use this video
Update (08/14/2021)
. Use this video
Update (08/14/2021)
. Use this video
Puntuación 1
1 comentario:
Worked great. Thanks I’ll be my granddaughter’s hero.
- de
This also happened to me and I put it back together but now it won't work, was yours fully functional after?
Puntuación 0
2 comentarios:
Yes, it works normally now. Though the lens part periodically pops off, so I have to press it back on. But it functions the same.
- de
have you made sure that the batteries are put in correctly? It feels stupid to say but that was my problem after putting it back together
- de
The back black piece around the lenses was loose and I ended up losing it after some time. In order to solve that, I am 3D modeling that piece and will print out soon. Even though it is still not possible for me to print out the notches (they are two tiny, and I couldn't find any disasembled piece to copy) I hope it will work out and prevent from dust get inside of the camera. If someone is willing to help me (with pictures/ dimensions of the isolated piece) I'd be more than happy to share my 3d files :)
Puntuación 0
1 comentario:
Hello Larielarie. Have you 3D printed this? If so I'd be interested in getting the file from you! I need to print one for my camera! Thank you!
- de
Where can I find a replacement piece for the video above! The lens barrel end?
Puntuación 0
Añadir tu respuesta
Joanmary Lavitz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 95
Ultimos 30 días: 433
Todo El Tiempo: 73,308
