My n 70 nokia phone signal is not working
my n 70 nokia phone signal is not working
Es esta una buena pregunta?
Hi,
Please try the following ways.
1) Go to settings --> network and select manual option and see if its showing any other networks. If you can find your network just select it and you will be connected.
2) if not you can try to remove the sim wipe it and put it back again see it works.
if it still doesn't work, you can contact your telecommunication service provider. They will help you.
Regards
Abdul
Fue útil esta respuesta?
simcard not valid
Please make sure your carrier supports this phone.
The Nokia N70 only supports
2g 900, 1800, 1900 MHz
3g 2100 MHz
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 716
