Saltar al contenido principal
Modelos de MacBook Pro con una pantalla de 15"
Preguntas 8252 Ver todo
Why is my built in camera not working
my built in camera is not working. the light does not turn on with it (green light to the right) i have tried and spent a lot of time researching to see whats the deal with it but its still not working. i tried resetting my SMC and PMU. that didn't work. tried opening up with applications but it still is unresponsive. do you have any ideas?
Update
It's the first gen with a camera and is. 2.33 ghz processor. I don't have it with me right now. Sorry
Es esta una buena pregunta?
Puntuación -1
2 comentarios
another idea... does the camera show up in system profiler under USB?
- de
check out my revised answer above.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
It's possible that the cable has come loose. Which model MBP 15" do you have? You should be able to check out one of the guides for your model which will show you up to the point of pulling out the isight camera cable. If I knew your model I could direct you to the most relevant guide.
edit
check out the below guide up to step 13:
MacBook Pro 15" Core 2 Duo Model A1211 Inverter/Camera Cable Replacement
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
amb5377 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 7,106
