4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
Preguntas 17 Ver todo
How to change country code?
Hello
I have a MC340LL/A model and have to use it in Europe
airport utility in the option network show only US and america country ...how to correct this in order to respect local legislation as the AEBS is supposed to be compliant to world regions regulations ?
Thanks for any hints
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Hey @Philippe P, did you solve this problem of change firmware region on Apple AirPort using the Java solution commented by @mayer ?
I saw the specifications of the Java software, and I believe this program only helps to access the equipment without the AirPort Utility, with no advance (plus) settings, like change the network country firmware (region).
Best regards!
por
Agregar un comentario
2 Respuestas
Solución Elegida
Here's a Java-based configurator for the Apple AirPort Base Station and Lucent RG-1000 wireless access points. It should run on any platform with a Java 1.2-compliant runtime environment installed, permitting the configuration of a base station from any host.
http://gicl.cs.drexel.edu/people/sevy/ai...
Fue útil esta respuesta?
Calificación 2
Comentarios:
por
This is a firmware-based setting that I don't believe you can change; it's a fairly common request but I've never seen a solution.
See e.g.:
Calificación 0
Añadir tu respuesta
Philippe P estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 25
Últimos 30 Días: 107
Todo El Tiempo: 10,250
