Why does not the display screen work?
Sometimes the LCD display will go black for seconds before turning back on to normal.
Es esta una buena pregunta?
There could be an issue regarding the power connection. Make sure the battery is good first and then check all the wire connections. If that isn't the case, follow the disassembly guidance and take it apart and check if the LCD needs to be replaced.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 327
