Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
Preguntas 3238 Ver todo
Why won't iPhone restore?
I was expeencing some problems, so I thought I would restore my phone. The proces was going smoothly, and then when it finnished, it came up with an error that said
"There is a problem with your iPhone.
Please visit the Service Answer Center to find answers to all your questions about service options, warranty and other processes in your country.
To find your nearest Apple Store, click here."
Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
when you power your phone on, it shows a small blue "i" on the bottom right corner.When you click it, does it show a IMEI Number or is it blank ?
por
theres no "i"
por
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Try placing the phone into DFU mode then try a restore in iTunes again.
Do the following in sequential order straight after each other.
  1. Plug your device into your computer with a USB cable.
  2. Turn off the device.
  3. Hold the Power button for 3 seconds.
  4. Hold the Home and Power buttons for 10 seconds.
  5. Release the Power button but keep holding the Home button.
  6. After about 15 seconds you will be alerted by iTunes saying that it has detected a device in Recovery Mode.
Let me know how you get on.
Fue útil esta respuesta?
Calificación 1
Comentarios:
I tried that, it just has the same problem
por
Are you trying to restore to a particular version of iOS?
por
no, I would just be happy to get it to work
por
Try the restore process on another computer, i've had an issue like this before which turned out to be a problem with iTunes on the particular computer I was using. Try using a friends / family members computer.
por
Añadir tu respuesta
Ben Russell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 9
Todo El Tiempo: 1,122
