Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
Why won't iPhone restore?
I was expeencing some problems, so I thought I would restore my phone. The proces was going smoothly, and then when it finnished, it came up with an error that said
"There is a problem with your iPhone.
Please visit the Service Answer Center to find answers to all your questions about service options, warranty and other processes in your country.
To find your nearest Apple Store, click here."
Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
when you power your phone on, it shows a small blue "i" on the bottom right corner.When you click it, does it show a IMEI Number or is it blank ?
- de
theres no "i"
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Try placing the phone into DFU mode then try a restore in iTunes again.
Do the following in sequential order straight after each other.
  1. Plug your device into your computer with a USB cable.
  2. Turn off the device.
  3. Hold the Power button for 3 seconds.
  4. Hold the Home and Power buttons for 10 seconds.
  5. Release the Power button but keep holding the Home button.
  6. After about 15 seconds you will be alerted by iTunes saying that it has detected a device in Recovery Mode.
Let me know how you get on.
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
I tried that, it just has the same problem
- de
Are you trying to restore to a particular version of iOS?
- de
no, I would just be happy to get it to work
- de
Try the restore process on another computer, i've had an issue like this before which turned out to be a problem with iTunes on the particular computer I was using. Try using a friends / family members computer.
- de
Añadir tu respuesta
Ben Russell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,286
