Repair guides and support for motherboards and CPUs.
Preguntas 67 Ver todo
Where to buy replacement CPU socket?
Greetings,
Where can I buy a replacement CPU socket? I have searched and searched and only been able to find one store on eBay in China. Anyone know a place in the US?
www.ebay.com/itm/Original-New-Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
"Charles, if you can find one, how would you solder the hundred + connections?"
You do not solder. You heat the socket with heat gun to melt solder balls.
por
Would be better to buy another motherboard.
por
Im bga certified, I just need the part
por
EBay and how much to fix my motherboard same problem jandersen
por
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
2 Respuestas
Solución Elegida
Charles all searches came up Shipping from China/Hong Kong/Taiwan to worldwide (7 to 19 business days) for the replacement CPU socket Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262. It may be worth trying to place the order on Ebay for the price of part $3.59 and shipping $3.30.
Good luck with the part and installation.
http://www.ebay.com/itm/Original-New-Fox...
Fue útil esta respuesta?
Calificación 2
Respuesta Más Útil
Calificación 2
Comentarios:
They come with solder on the grid. You use heat gun.
por
Or you can BGA Reflow them if you have the balls and stencil
por
You just added a clean socket. No solder on it to reflow.
por
@mayer sounds like robert is referring to a reball. Solder balls and stencil combined with a rework station can accomplish this task.
por
Añadir tu respuesta
Charles Kensington estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 42
Últimos 30 Días: 202
Todo El Tiempo: 3,376
