Sony Xperia Z3 Compact released in Sep. 2014.
Preguntas 87 Ver todo
Lower Loudspeaker doesn't work
Hi there, after the LCD replacement the lower loudspeaker seems not working anymore (also if replaced, so I think the problem is not the speaker itself but maybe is missing the connection between it and the MOBO). How is it connected to the MOBO? Maybe trough the black plastic bezel which contains the screws? It is broken in the left side, it fits good but maybe this is the problem that cause the malfunction?
Waiting 4 your kind reply
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Hi Maria
Did you solve the issue with lower speaker?
I have the same problem after replacing lcd
por
Agregar un comentario
2 Respuestas
I will think the loudspeaker wasnt install correctly can you take a picture if you can.
Fue útil esta respuesta?
Calificación 0
Comentarios:
It is already installed in the replacements lcd I bought
por
Hello. I know that I write after a long time I just would like your help.
I have the same problem with the bottom sound, after replacing the battery, and while I did not cause any damage, it does not work at all at the bottom.
Have you solved this problem?
Calificación 0
Añadir tu respuesta
Maria Aurora estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 20
Todo El Tiempo: 608
