Saltar al contenido principal
Guías y soporte para varias marcas y estilos de TV.
Preguntas 9035 Ver todo
Sceptre lcd tv model x322BV no sound, no picture, No signal
I have a Sceptre 32inch LCD TV which after being turned on shows the Sceptre logo on the screen and then turns blue stating no signal on the screen. The tv does not have sound or picture. I was wondering if it was the power supply or the mainboard which is causing the problem. The model is X-322BV-HD.
Es esta una buena pregunta?
Puntuación 4
2 comentarios
Anytime I press any button on the remote the tv just shuts off buttons on the tv do not respond at all
- de
Hi @ allensparalaw,
What is the make and model number of the TV.
Does the power indicator light change colour when you go to turn the TV on?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
The power supply must be working as the logo and blue screen and message are appearing. The no signal might be that the TV is not switched to your aerial but rather to one of the other inputs available on your TV e.g. USB, YSBPR HDMI,etc. Just wondering if you get any response when you press the "TV" button on the remote. Try the "Source" button to cycle thru all your inputs. Also check that your aerial lead is plugged in correctly.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
la23197 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 8,103
