My tablet won't turn on, even after charging for hours
How can I get my tablet to turn on? I tried the factory reset, but still no luck.
Es esta una buena pregunta?
Hello Jenny,
Hope below steps will help you to turn on the Tab back
if above steps not works for you check the charger whether it works or not
Fue útil esta respuesta?
Having a similar issue with a tablet I've been given to repair.
Customer having troubles with it turning on and charging, even tried disconnecting and reconnecting the battery and he said that worked temporarily.
I've plugged in a battery tester on it, and the current going into the tablet through the charging port is inconsistent, meaning that the charging port is most likely damaged.
In order to fix this issue, the charging port can be replaced so that the battery can be charged properly again.
My tablet is still of after a couple hours I have tried charging it, doing power button and home button pushing down and nothing is happening
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 952
