Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Preguntas 162 Ver todo
Use of Samsung 950 PRO M.2 256 GB SSD
Hello!
I have the late 2013 27" iMac and I know it has a PCI-e SSD connection slot. At the moment it's not in use. (only a 1TB HDD).
I do however have a Samsung 950 Pro M.2 256GB SSD.
Will it work, if I use the iFixit guide to take the iMac apart and insert this M.2 SSD?
In other words, will I have fusion drive activated between the 1TB HDD and the SSD?
It's a lot of steps to open up this iMac and I would not be very happy if I place the thing and it doesn't work... Hope to hear from you!
Update (10/26/2015)
Thank you for the respons!
There seems to be a lot of confusion.. I read in some tech articles that the connector used has the standard M.2 interface.. :( sure it won't fit?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Sadly it isn't compatible. Here is a picture to compare to the one I have below: Samsung 950 Pro SSD
por
Apple is using a PCIe interface just one that is of their own design. Samsung is manufacturing the custom part for them using the same design as the M.2 950 Pro SSD.
por
Could you point out the difference? I can't seem to spot it.
por
Compare the SanDisk SSD image below to this image of the Samsung drive above. Note the slot in the connector pins the slot is located in a different location. This is the keyway and the connector in the system will not mate up correctly with the pins,
por
Hi,
I am also looking to buy a late 2013 A1419 and I was wandering :
1. it the machine came with a 1T HD no fusion drive. Will the SSD conector be there?
2. would this drive from VisionTek fit: https://www.visiontek.com/images/stories...
The pinout seem to be alright?
Thank you,
por
Agregar un comentario
1 Respuesta
Solución Elegida
First you'll want to review the IFIXIT guide: iMac Intel 27" EMC 2639 SSD Replacement.
If you look at this Sandisk SSD you'll see Apple has a slightly different connector on their SSD's. The M.2 SSD won't fit.
Fue útil esta respuesta?
Calificación 4
Comentarios:
If those connectors are double sided then the SanDisk smaller side is 24 pins connector, the Samsung 950 pro is 10 pins but the connector from the iMac shown in the Guide above is 16 pins. I don’t understand. See picture: https://d3nevzfk7ii3be.cloudfront.net/ig.... If that's the case then the only drive that would is the vision tek. Are my assumptions correct?
Thank you,
../Bruno
por
The issue here is they are based on different connector standards. Blade SSD's need to match up with the standard the system uses.
por
Hello Dan. As if for 2018, is it now possible to install Samsung 960 Evo or Pro to iMac 27" late 2013 (its iMac 14,2)? From what I know - there is an adapter to match the PCIe Apple connector to the NVMe so it matches Samsung NVMe m.2 disks. As I know already macOs High Sierra supports NVMe - I dont see any thing that block me. But Im still worried about a few things - does my mac for sure has the PCI plug? And second thing - Is it possible that adapter will be maybe a bottleneck for the speed of disk?
I would appreciate answer.
Thanks
Robert
por
If your willing to try give it a go! I would rather go with the correct SSD than use an adapter.
We tested the SATA (AHCI) based SSD's and the adapters were just junk at that time point and the timing within the SSD's was different enough we where seeing a lot of CRC errors. I haven't tried them since our original testing at the time we where testing in a MacBook Pro's not iMac's
por
I see, ok, thank you very much for you reply. I think I will stick to what I am more sure that will work. Thanks !
Rob
por
Añadir tu respuesta
Daan H estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 21
Últimos 30 Días: 133
Todo El Tiempo: 8,491
