GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Preguntas 178 Ver todo
Ipad 2 is not charging, no turns on, black screen
Hi,
my Ipad2 GSM does not charge and does not turn on. (Working properly before discharging)
The charger and the cable were tested and working properly.
The connectors are clean and without damages.
By connecting it to a PC is not recognized
Ideas on what might have?
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
6 Respuestas
Have you ever charging for too long? It is likely a hardware problem like mainboard is broken.
Fue útil esta respuesta?
Calificación 0
No, I have always paid attention to the charging time and I never left the device on charge more than necessary.
Before it was fully discharge by connecting the charging cable appeared to me "device not in charge" but the cable and charger are ok.
It is not possible that it is damaged (for some reason) the flat cable between the charging connector and the battery or connector or something similar? unexpected death of the battery?
Calificación 0
Have you tried resetting it by holding the home and power button at the same time for 10 seconds ?
Calificación 0
Yes, I tried but no response and no Apple logo (although I think it's due to the fact that the battery is low). Other ideas?
Calificación 0
Some other tests or possible causes of the problem?
Calificación 0
Comentarios:
Have you tried a reset or DFU mode ? Were there any symptoms of a problem before this happened? Crashing? Quick discharge of the battery?
por
I tried it but the combination power + home gives no result, by connecting the device to the PC is not detected and never gave any sign of abnormalities or sudden blocks.
It reported that the battery was used as normal and once the discharge everything and as if you are unable to charge more
por
Is there any answer?
Calificación 0
Añadir tu respuesta
ModMatrix estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 497
