The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
Preguntas 11 Ver todo
How do I turn off the front panel LED light?
The LED light on the front panel of the Roku 3 is constantly on, and at night the brightness of the LED can be annoying. Is there a way to turn off this light?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
9 Respuestas
Solución Elegida
Hi,
There is no setting to turn off the light. Try covering the light with a small piece of electrical tape.
If you are using the remote that came with the Roku 3 you do not have to worry about covering the IR sensor, the supplied remote is RF.
There is this product (even though not available from them at this time - maybe somewhere else)
http://www.thinkgeek.com/product/eeb6/
There is also further info in this link
http://forums.roku.com/viewtopic.php?p=3...
Fue útil esta respuesta?
Calificación 3
Respuesta Más Útil
On your Roku remote hit follow the sequence: home button (5x), FF, Play, Rewind, Play, FF - this gets you into a secret menu. Choose adjust LED brightness and you can reduce the white LED light to 0%. :-)
Calificación 6
Comentarios:
i thought this was a joke but on a whim i tried it and its real. hilarious
por
this works!!!
por
The menu is real. Unfortunately the LED option is not.
por
Yep this works. I can still see the light at night even at its lowest setting, but it's much better. Couldn't believe it worked. Lol
por
The LED option was there for me. Thanks.
por
Mostrar 5 comentarios más
There is a way to do this. After you finish watching your programs from your Roku player just click on the top Home button icon that will take you back to the home page on your Roku. Once there select on your TV remote the source button and select TV or Cable TV, which ever one you have. Once it's back to the TV then turn off your TV. The Roku box will shut off, light and all, between 15 min to an hour. If you do not exit what you are watching on your Roku it will continue playing the programs. That's why the light stays on.
Calificación 3
Comentarios:
This works. Took only 10 min.
por
For all of you who have been wondering how to turn off your Roku 3 device well it's true there is no way to turn it off but to unplug it. I have found a way to turn off the light and allow it to go in to "sleep mode". You can pair it as an Anynet+ device on your TV. Then on your Roku settings go to Screensaver and put your time setting to 1 minute. So when you get ready to turn off your TV, press the home button on your Roku remote so it will not continue to stream, then turn off your TV. The LED light on the Roku will turn off automatically within one minute. I hopes this helps everyone. Advance to Roku offer an off switch on your devices. If you add an additional setting to where the consumer can set when they want updates to be installed, they can be sure to have the device on at that time so that the update can begin. This will give your customers a peace of mind with your product.
Calificación 2
Comentarios:
Thanks! This worked!
por
There is no official way to do this. You'd have to unplug the power source. You can use your TV as a remote but that requires setting up and a SmartSwitch.
The Roku 4, to date, is the only device with some sort of way to power it off. You can read more about it https://www.orduh.com/turn-off-roku/,
Calificación 0
Put Black tape over the light
Calificación 0
Hello,
At the point when the LED lights on the front board are on, the Receive and Send LED lights can be changed from strong Blue to Green with the goal that the majority of the lights are similar shading. This is very easy to turn off the front panel LED light, just go to the Configuration link on the main menu and click the turn off front panel LEDs except power LED drop-down menu and select Enable. For more help visit https://www.roku.com/ and read some instruction. If you need some instant help then visit here and get instant help. http://www.customer-support-numbers.com/...
Calificación 0
Comentarios:
Home. > settings > system > power > standby LED select “off”
por
Home > settings > system > power > Standby LED ...select off
Calificación 0
Hello. If you are in search of any technical help for Roku 3 device, then just call Roku Support Number. Here, you can directly talk and discuss with the highly professional and skilled team for all your issues. You may call this customer care number anytime.
For more informatio, you may visit: https://goo.gl/9zLXkN
Calificación 0
Añadir tu respuesta
Kasey Evans estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 113
Últimos 7 Días: 781
Últimos 30 Días: 3,356
Todo El Tiempo: 59,805
