Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2693 Ver todo
Can an iPhone 6s Screen be transferred onto a normal iPhone 6?
I recently shattered my iPhone 6 screen and it's no longer working, and I'm extremely interested in the 6s but don't want to drop $900 for a new phone when mine just needs a new screen.
So, my question is I can purchase an iPhone 6s screen and install it to a iPhone 6, and would it work?
I'm extremely curious to if this is possible and willing to try.
Es esta una buena pregunta?
Puntuación 19
3 comentarios
it works i just did it
- de
I just Put the iPhone 6 screen on iPhone 6s Chasis and its work i guess the people that tried 6s screen on 6 chasis doesnt work
- de
My 6s recently crashed and won't turn on or charge I tried unplugging the battery and connectting it back but nothing happened
- de
Agregar un comentario
16 Respuestas
Solución Elegida
This is not possible for a couple of reasons.
  1. The FPC connectors are not going to be the same. Throughout the history of the iphone no two models have had the same FPC connectors. If you look at iPhone 3 vs 3gs the connections weren't the same. Then with the iPhone 5/5C/5S, none of those were the same either. Now, I have not seem a screen for the 6S yet but I am confident that the connections between the 6 and 6S are going to have at least a minuscule difference, if not being profoundly different all together.
# Even if the connections were EXACTLY the same it is very doubtful that the LCD would work due to programming differences on the logic boards of the iPhone 6 and 6S. Not to mention the difference in hardware (e.g. touchforce 3d Screen on the iphone 6). Not only do you have mechanical differences between the two pieces of hardware, there are also dimensional differences that would make seating the thicker iPhone 6s LCD into the housing of an iPhone 6 an impossibility.
Hope my answer helps.
Fue útil esta respuesta?
Puntuación 16
10 comentarios:
I change the glass on a iPhone 6s today and last week I change the screen on iPhone 6,and I don't no about the size but the 6s has 3 doc connectors and the 6 has 4,and the power one is totally different,so the answer is deffo,no it won't fit,
- de
"Throughout the history of the iphone no two models have had the same FPC connectors."
Until now. The iPhone 5s and iPhone SE LCD display assemblies are EXACTLY the same.
- de
Actually @rscellandtech im sorry but you guys are in fact wrong. I just replaced my iPhone 6 with my iPhone 6s screen along with the LCD homebuttion plate. The cords will go right in there and everything works properly, I am on the phone as we speak
- de
HomeButton plate. *
- de
I hope you're right Sara, I'm going to be upset when I take these phone apart and its not what she say please be right.
- de
Mostrar 5 comentarios más
Well, funny story. Because people keep asking if they can put an i6 screen on their i6S. The general consensus is no. However your question is kind of the opposite. So you want to use the i6S screen? Which near as I can tell, doesn't have readily available parts. But, if it did. They did use some i6S parts, a digitizer/lcd, on an i6. And it didn't exactly work, from the pictures. This was pre-release. All that was shown, was the screen lit up, with a gear logo on it. So, would it work? Maybe. Would it do what you want? Not sure, if you could just get an i6 lcd/digitizer anyways?
Puntuación 4
3 comentarios:
@imedicminneapolis
Yes, I want to put an iPhone 6s digitizer/lcd on the iPhone 6. Repairing my iPhone would only cost $109 at the closest Apple Store, but this is just an idea that I had.
- de
I love the idea, but like I said. It's pretty doubtful it'll work. The best you'll probably get is a display, that won't properly display. I would just find a replacement i6 display assembly. Like here
iPhone 6 LCD and Digitizer
- de
I belive that the gear would of been due to internal apple software (not internal UI which is development iOS) but most likly switchboard that is used mostly for device diagnostics. Mostly found on prototype devices but can sometimes be flashed onto a device
- de
Transfer iPhone 6 to 6s LCD, Just 7 Steps
http://www.rewatechnology.com/article.ph...
Puntuación 3
1 comentario:
link not found.... tells me this is also a troll
- de
As a phone tech I could honestly say this will not work because of the logic boards connection between the screens, they look the same but they physically have different puzzle connections so even if it seems like it would work it wouldn't because the screens connection won't line up with the logic boards connections, and the 3D Touch feature on the 6S series is the main reason it wouldn't work.
Puntuación 2
2 comentarios:
Correct! Use the iPhone 6 screen with the iPhone 6 and the 6s with the 6s otherwise you will damage your motherboard connectors trying to connect it.. all connectors for each model is always changed by Apple! Always! Screens are cheap although motherboard issues results in a new phonemost cases!
- de
Do you mean different like the 4 and 4s?
Im unsure why people need to comment without knowledge on the subject
- de
You should be able to find an iPhone 6 screen for sale more easily than a 6s screen. If you already have a 6s screen, I'd recommend selling it on eBay etc. and using the money from that to buy a 6 screen.
Puntuación 1
hello sorry to everybody , it looks that after a week my screen stop working , the display is like a glitch on the whole screen , it was like new firts no problem at all ,but now is a complete glitch sorry
Puntuación 1
Hi will my Atari and Coleco Vision Games still work in my PS4Vr cause i really like mouse trap and donkey kong
Puntuación 1
All these great replies from people that haven’t actually done it : ( …means they are just opinions.
Puntuación 1
http://www.macrumors.com/2015/08/10/ipho...
copy and paste in top bar
Puntuación 0
Actually i just installed a iphone 6s screen on my 6 and it does in fact work perfectly. Practical will always beat theory.
Puntuación 0
3 comentarios:
so you really got it to work? cause i'm about to give it a shot!
- de
No, you didn't. I literally just tried it 10 minutes ago. The connectors are physically different. The 6 screen also has one more connector than the 6s screen (4 vs 3), and only one of those connectors is the same size between the two.
- de
I’m using iPhone 6s display on Iphone6.it works well
- de
Im about to do it you better be right i dont want to spend $700 on a new one
Puntuación 0
1 comentario:
I did it. It worked im so happy
- de
Would iPhone 6 screen work in iPhone 6S?
I have a broken iPhone6 screen but only iPhone 6 replacement screens. Should I try?
Puntuación 0
Hi everyone.
I have not in theory tried but couldn’t do it too easy. The heat ended up the phone and it crashed, not a good buy to lead into this idea. Maybe try another month again.
Puntuación 0
I just pulled open a 6 and a 6s hoping to swap the screens. The screen is shattered on the 6 and the 6s was having gps issues. I was hoping to get one working phone out of it. As stated above, the 6s has 4 cables connecting it to the phone board and the 6 only has 3. I don’t see any way people got that to work! Of course, I just assumed they were the same when I started and didn’t see this thread until after I had opened up both phones.
Puntuación 0
Can i put my iPhone 6 screen on my iPhone 6s
Puntuación 0
No impossible guys. IPHONE6 & IPHONE6S both use different Connection on the mainboard.
Puntuación 0
Añadir tu respuesta
Nafez Husseini estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 52
Ultimos 30 días: 195
Todo El Tiempo: 219,894
