Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
Preguntas 74 Ver todo
Keurig K40 not brewing
Heats up, cup lights flash, press any cup size, hear rotating noise and then nothing. Couple minutes later all three lights come on.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
I have a Keurig it runs the water through but as soon as I put a cup in it won't work
por
Un plug it, take the water tank off, clean the piercing needle in the top with a straightened paper clip being inserted into it. If that doesn't work; try "burping" it like I did by lifting up on the handle, putting it front side down in the kitchen sink and taking off the bottom....it will do a power flush of the system.
por
Agregar un comentario
3 Respuestas
Solución Elegida
Harry Gray, could be caused by a clogged line or valve. Clean the valves and the line by using this guide
Fue útil esta respuesta?
Calificación 1
Comentarios:
While this detailed instruction is appreciated, a WARNING would be it is difficult to reassemble some of these parts, particularly rescrewing the reservoir filter and realigning and rescrewing the top covering. Also, this fix does not address the "machine gun" sound our K40 makes.
por
Worked like a CHARM!!!
por
It comes on heats the water can hear pump running nothing comes out to cup
Calificación 0
the best ay to fix all problems with this machine is to first fill the water reservoir up to but not past the max fill line. After filling reservoir with cold clean water, drop your cell phone into the reservoir with the water. The Keurig machine is just lonely and wants to call home, which it will do using your cell phone...... wait approximately 17 minutes and 16 seconds and then remove your phone from the water reservoir. Now your machine will make really good coffee
Calificación 0
Comentarios:
Good call. it worked except one problem. When coffee is done police comes to the house and takes the coffee. Keeps calling 911 when done making coffee :)
por
Añadir tu respuesta
Harry Gray estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 42
Últimos 7 Días: 250
Últimos 30 Días: 1,231
Todo El Tiempo: 15,949
