Mid-range desktop PC made by Dell. Model number 4600.
Preguntas 15 Ver todo
Why wont anything come on monitor screen?
Both the tower and monitor have power to them. Vable connected between them properly, yet the monitor does not show anything
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sam I Am,
Start trubleshoot from monitor
  • Connect it to laptop or any other supported video output to check wheter monitor is works fine
if the monitor working,
you should begin to troubleshoot the PC
Here you can find the Video card replacement guide. you can remove the video card and clean the card and motherboard interfaces and reinstall video card and check whether PC video out works fine
if above steps not help to solve you issue or if you PC run with on board graphic controller you can remove RAMs and clean the interfaces and reinstall RAMs properlly. and check whether vedio out start to work back
Here you can find RAM replacement guide,
Cheers!
Imagen Dell Dimension 4600 Video Card
Guía
Dell Dimension 4600 Video Card Replacement
Dificultad:
Fácil
5 - 10 minutes
Imagen Dell Dimension 4600 RAM
Guía
Dell Dimension 4600 RAM Replacement
Dificultad:
Fácil
10 minutes
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Sam I Am estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 7
Últimos 30 Días: 46
Todo El Tiempo: 615
