Why does my laptop turn on but no image?
Laptop powers on, fan runs and all lights power but screen has no image.
Es esta una buena pregunta?
Cancelar
A business-class notebook with a 13.3" touchscreen display.
From the information you have provided me with, there are a few possibilities as to what might be wrong with your laptop. The most likely of these possibilities is that your motherboard or graphics card may need to replaced. For more information on the subject and repair guides on how to fix the problem you should refer to the troubleshooting page for this device.
First try a static discharge this is done by disconnecting the battery then disconnect the power adapter with no power at all to the laptop. Then hold the power button down for 60 sec then put the battery back and plug it in and start it up. If this doesn't help try connecting to an external monitor .If this works then we know there's a problem with the screen . If this doesn't work we can now look at the motherboard or video card
Comentarios:
my laptop screen light is out i use your tip and its work and screen light is turn on thanks a lot
por Aamir Saeed
With the limited information provided, it is hard to determine the issue. However there are several steps (others has already mention some of them) that you can perform to isolate the problem to include the following:
1. Disconnect AC adapter and remove battery. Once you have removed the battery, press and hold the power button to ensure all power has drained from the motherboard. Reinsert battery and connect AC adapter, then power on device. If this resolves problem, device was probably hung up.
2. With device turned off, connect laptop to external monitor via VGA or DisplayPort and then power on device. If laptop produces any output to external monitor, there might be an issue with the laptop LCD screen or internal cables.
3. With device powered off, replace memory modules and then power on laptop (this requires opening the laptop and should be performed by someone that knows how to repair computers). If the device powers on, the RAM might have been defective.
Are there any POST/BIOS beeps or sounds when the device is powered on? If you have a another device that is powered by USB (smartphone), does it show a charging status when plugged into a laptop USB port after being powered on? If these steps do not help, please provide additional information (ie. was the device recently dropped , has the laptop recently received an Windows update or have you upgraded to a new operating system)?
Comentarios:
My 840 will power on for 2 seconds and then power off and sometimes will do this several times. A couple of times I closed the lid and when I opened it back up it had gone to missing boot device screen because I have no hdd in it. I have tried all the above but no changes. Bought this from a recycler so have no history on it.
por Loren Robinson
I have the Same issue with hp elitebook 8440p.when i try formatting then it starts rebooting every second.does not last long for 5sec
Please help out
por michael quartey
Laptop on but no output and screen black no backlight how to solve
por CHINA MALL
i fixed mine issue by replace the faulty RAM which make the laptop to reboot every second ...... Thanks for the help
por michael quartey
@CHINA MALL ..... what type of laptop is it ???
por michael quartey
hey first of all did u try to connect it to outside monitor and see if it's working or not .
Ultimas 24 Horas: 18
Últimos 7 Días: 110
Últimos 30 Días: 427
Todo El Tiempo: 3,560
We have a chance to guarantee our right to repair electronic equipment—like smartphones, computers, and even farm equipment. This is a once-in-a-generation chance to protect local repair jobs—the corner mom-and-pop repair shops that keep getting squeezed out by manufacturers.
Join the cause and tell your state representative to support Right to Repair. Tell them you believe repair should be fair, affordable, and accessible. Stand up for your right to repair!
