Model 5234us. 1.66GHz Intel Centrino Duo
Preguntas 9 Ver todo
Why Access denied repairing EDB with ESEUTIL?
Hi
I'm trying to put a restored EDB in to a clean shutdown state (its currently saying its in a dirty shutdown state). However when I run the command I get this back;
Operation terminated with error -1032 (JET_errFileAccessDenied, Cannot access file, the file is locked or in use) after 30.93 seconds.
If I use handle.exe to show the handles for objects in use then that recovered EDB doesn’t appear in the list. The main EDB does but this recovered one (that will be part of a recovery group) doesn't.
There's no AV installed (I removed it to see whether this was causing the issue though it did have an EDB exclusion).
Any ideas what may be the cause?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
EDB to PST Converter Tool is an effective & reliable tool provides impeccable recovery. This tool recover & repair all damaged .edb files and then transfer them into usable format that is PST. It supports all versions of Windows and restore PST files in your location. It restores all files in original formats such as HTML, Text, RTF, etc. It is preview of all damaged or corrupted EDB files before restoration. Free availability of demo edition with the help of you can easily understand the complete procesdure of recovery.For more info, visit here- https://softcart.wordpress.com/edb-to-ps... or http://www.mozesoft.com/edb-to-pst-conve...
por
Marvelous Enstella EDB to PST Converter Software which easily available on online and helps to recover all different types of corruption issues from Exchange Server and gives Outlook PST and multiple formats to convert EDB Mailboxes Data with all zip attachment / properties/ journal / calendar / appointment etc. It permit that first time you can use demo version to export EDB Emails per folder into each formats without any cost.
Read More:- http://convertedbtopstfreeware.blogspot....
por
Agregar un comentario
1 Respuesta
Solución Elegida
I think it is the log file that is locked. You might try a few things- cheating by moving the log files to another location and only leaving the essential log files or checking the properties on the log files. Or you can try to restore the file from backup. And if you haven't it you can try to use third-party tools like EDB Repair Kit for example. Or try A reboot server. May be it help. Always make a copy of your edb files before running any maintenance on them. http://www.edb.repair/
Look also this authoritative source.
http://www.fixya.com/support/t25426221-r...
Fue útil esta respuesta?
Calificación 1
Comentarios:
I am very glad that you helped me
por
Añadir tu respuesta
ClementMoody estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 42
Últimos 30 Días: 136
Todo El Tiempo: 1,718
