Saltar al contenido principal
A 65" rear projection TV by Mitsubishi.
Preguntas 7 Ver todo
cap values on DM power board
I was getting ready to perform repair for blinking green light on my old Mitsubishi WS-65511. Pulled the DM power board and noticed the values on the caps are 1000uF 25V. I had read to buy replacement caps that are 1000uF 16V so that's what I bought. Any advice as to what to do? I'm confused. Thanks in advance.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
jrmcdown, I just double checked the schematic and the 1000uF are all 16V. May be these have been changed once before. You are okay with using the 16V per schematic.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks soldered in the new caps. Unfortunately must be something else. have constant blinking green light now. Thanks for answering my question though. I think the 25V were installed by TV repairman from previous problem.
- de
Generally, you are safe if you use over-rated caps. So you could replace 16v with 25v or 50v caps, but you wouldn't want to use 16v caps if 25v were required. - I've heard the 16v caps spec'ed by Mitsubishi are under-rated, so generally when being replaced it's a good idea to use 25v or greater.
Puntuación 0
Añadir tu respuesta
jrmcdown estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 339
