Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Preguntas 1497 Ver todo
Why wont it switch on, it only shows an apple on screen
when changing sim card i turned my phone off and changed but upon switching back on only an apple sign appears on screen and nothing else is happening
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
I noticed you never got an answer to this. Are you still having this problem?
por
Agregar un comentario
1 Respuesta
Solución Elegida
You need to force the device into Restore mode. With the device powered off, plug one end of the USB cable into the phone (don't plug it into your computer yet). Open up iTunes on your computer, then hold down the home Home button on the iPhone while you plug the USB cable into your computer.
Keep holding the Home button down until you see the "Connect to iTunes" graphic on the iPhone, then follow the prompts on iTunes to restore the firmware to the device.
Fue útil esta respuesta?
Calificación 5
Comentarios:
gracias muchas gracia me sirvio de mucho!!!!
por
Añadir tu respuesta
pete estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 4,440
