Saltar al contenido principal
Guías de reparación y soporte para Leapster L-Max, un sistema de juego de aprendizaje portátil para niños de 4 años en adelante, desarrollado y lanzado en 2005 por LeapFrog.
Preguntas 6 Ver todo
How do I get the battery to charge?
I cannot get the battery to recharge. The green light flashes while charging for more than 8 hrs. Battery still not charged. I have cleaned the terminals as recommended by the company, but no luck.
I am willing to buy a new battery if I could just find one.
Es esta una buena pregunta?
Puntuación 3
1 comentario
Mine has batteries in it but isn't charger not even turning on what do I do is there anyway to reset it?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
i searched ebay a little bit and found a battery cover/holder.
i don't know whats normally in the leapster l-max - but this holder looks like a 4 x aa battery holder: CLICK
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Hi.
1. you can buy a wall charger (charge the battery connected to the wall socket) and connect to the ipod.
2. electro Shocks to your battery. You can use a power supply of 5V (for example an AC adapter with this power) and connect with a terminals to the pads of the battery this only has to be for a seconds, otherwise the battery will be burn.
after this process you can chek your battery with a multimeter
Puntuación 0
You plug in the charger to the wall, and then put it into your leapster device.
Puntuación 0
Añadir tu respuesta
Ruth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 5,636
