A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Preguntas 726 Ver todo
Anyone got ANY idea where this goes
Anyone got ANY idea where this goes? I need to find its home to repair my drive. No images have helped me yet.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
I found this piece loose inside but the spring is missing. Will everything work without this piece installed?
por
Yes, it will work just fine. The thing to be worried about is where that spring went. If it's inside the disc drive somewhere it could cause it to malfunction.
por
Agregar un comentario
3 Respuestas
Solución Elegida
Yes...if you look at the top picture in the post above yours on the right side you will see there is a plastic part that juts out from the side about in the middle. You will see what looks like a plus...this is the bottom side of that gear (the side without the spring on it).
Incidentally you don't actually even need that screw. It's the manual eject screw and the drive will work just fine without it. It's good to have in case your disc gets jammed in there but you could do without it if needed.
I hope this helps.
Fue útil esta respuesta?
Calificación 1
Comentarios:
It was causing disc read errors but is working great and got the info from a post you made almost two years ago, but again ty!!
por
Great to hear! I've added the photo with a circle around the part I was talking about just for anyone else that might have problems with this in the future.
por
thank you for posting this, but how do I hold the spring in place, it falls off
por
There should be no need to hold it in place. The black cover that goes over the laser holds it in place.
por
Respuesta Más Útil
Just to assist Tronicsfix with the identification
images from What is this mystery piece I found inside a PS4's optical drive?
Calificación 1
Comentarios:
Didn't even think of that...I've also never done it before so wasn't aware of how easy it was. Thanks!
por
Guys if you looked I already thanked him from an older post. But thanks for all your info and II have my PS4 back up and running. Not bad for a total of $70 invested for a PS4 with a broken HDMI port.
Calificación 0
Añadir tu respuesta
atreyu187 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 23
Todo El Tiempo: 810
