double image one minute after starting
sony ex330 is workin well ant after 1minute the picture will become double downwords like ghos?t
Es esta una buena pregunta?
manobabu, sounds like a T-con board issue. Check your wiring from and to the T-con board. Also, check for obvious damage, like burned, swollen or leaking caps. In very few instances this can also be caused by a faulty power supply. Once we can determine exactly what model your TV is, we can most likely find more specific instructions.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,556
4 comentarios
manobabu, is it a KLV-32ex330?
- de oldturkey03
I have the same problem and the exact same tv model!! man these things arent made to last..
- de dugadug27
same problem with my tv KLV32ex330
- de saurabh singh
Im technisian ,,in need this fault solution
- de Jeeniwe Jesus
