Saltar al contenido principal
La actualización de marzo de 2015 de la pantalla Retina MacBook Pro de 13" de Apple, modelo A1502, presenta procesadores Intel Core i5 e i7 de quinta generación e introduce el trackpad Force Touch.
Preguntas 1186 Ver todo
Knocking sound when tilted - around top of keyboard or screen area
There is a distinct knocking sound when tilting the Macbook. It feels like something is sliding and knocking the metal casing, but it's extremely had to identify exactly where. It sounds and feels like something heavy, possibly a battery, but the batteries are towards the front (and stuck down!) The knocking sound is coming from the bottom of screen area, more towards the right but across the length of the hinge.
This has baffled me and there appear to be more people with this issue - is it the fan moving on it's axial?
Is there something loose in the screen itself? - it does sound like something heavy, flat and moving side to side (it's absolutely not a loose screw or something 'rattling' around).
Is there a solid metal bar/fixing in the hinge area it could be?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
You'll need to bring it in for warranty repair that's not good for a new system!
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If the sound repeats its the fan blade hitting the fan housing as the bearing is bad. As long as you haven't banged your case this should be able to get this fixed under warranty given your systems age.
Bring your system into an Apple Store or Apple authorized service center to be looked at.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Jaybe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 1,042
