Saltar al contenido principal
Procesador: procesador Intel® Core™ 2 Duo T5750 2.0 GHz
Preguntas 12 Ver todo
Pregunta Cerrada
Why is heating my laptop
how do i resolve problems with heat in my processor
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Solución Elegida
You may want to replace the thermal paste. The fan and heat sink can be removed with this guide.
If your new to thermal paste installation, check out this.
Imagen de Electronics Skills
Guía
Cómo aplicar pasta térmica
Dificultad:
Moderado
5 - 20 minutes
Imagen de Gateway SA1 Cooling Fan
Guía
Gateway SA1 Cooling Fan Replacement
Dificultad:
Fácil
10 - 15 minutes
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
hi there. with regards to your problem, may i know how old is your notebook? and in what places you're using this? for the first possibility of overheating is DUST on your fan. the longer we use our notebook the more dust it will take inside. and for the place where you are using it...if you use this in a room where dust are everywhere then you need to open your notebook to clean only your fan. then try to boot again.
second possibility is that your fan needs to be change when it rotates very slowly. hope this will help. cheers.
Puntuación 1
1. Remove dust from heat sink
2. Replace thermal grease between processor and heatsink
3. Use your laptop on a flat surface
Puntuación 1
i need new batery
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,338
