Saltar al contenido principal
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
Preguntas 95 Ver todo
Tablet wont charge or come on
The tablet wont charge or turn on at all. The screen is totally black and this is the second one that I purchased and it has some kind of problem with it. It was 80.00 wasted. What can be done about it?
Es esta una buena pregunta?
Puntuación 8
2 comentarios
this is also my second nextbook had a problem with screen not coming on with other one sent back this was a replacement. getting tired of them not working !!!
- de
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Sharon Withrow, start with a new cable and an AC charger. then check the micro connector to make sure that the cable fits properly. If that does not do anything, replace the battery and double check your power adapter. Make sure it is still properly mounted to the board. If that does not work, you most likely are having logic board issues. If under warranty, replace it. Use these guides to work on your tablet.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
but seriously, its getting power as the red light goes on so dont try to say its the charger. and do they even sell the batteries as they are wafer ones glued inside the tabet
- de
Denver J. Yorton, CPhT Seriously! You obviously have not read the original question! Yes, they do make batteries for that one as well.
- de
I bought mine brand new when the battery died never came back on nor will it charge at all. Tried several different chargers and cords still nothing but a 100.hole in my pocket. Don't know where to send it or should I just beat it with a hammer
Puntuación 0
Añadir tu respuesta
Sharon Withrow estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 6,057
