A Wi-Fi and NFC capable CMOS camera first released in March 2013. Identified by model number EV-NX300ZBQUUS.
Preguntas 22 Ver todo
Why does the image freeze in capture mode?
Hello,
I have had a NX300 since a couple of years. A couple of weeks ago it fell (it was in a padded bag) a few feet to the ground. After that it was only showing a black screen (with menus still visible) in capture mode. It also doesn't turn off when flipping the switch to off mode. The shutter is not closed, since I had read elsewhere that that might be the problem.
I discovered that if I enable 'sensor cleaning', then it actually does show an image after turning it on, but after about 4 seconds the image freezes. After freezing I can get it to power off normally.
Does anyone know what the problem might be?
Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
I have the same problem as well! What's funny is that this problem happened also because I dropped my camera. I just wanted to let you know that I will be going to a camera repair shop soon and see what the problem is, if they can even find a solution.
por
Agregar un comentario
1 Respuesta
Did you ever find a solution? I have a wedding in 8 days and this is my only camera!
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
JF estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 125
