Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1526 Ver todo
Why are there so many different screw sizes?!
So I've taken apart my iPhone 6 plus several times trying to fix numerous problems due to juice spill. Some screws got lost, and I didn't keep track of which ones go where. I ordered new set of screws. I bought electric calipers to measure each screw. The problem is there are so many different measurements. I'm trying to find a 2.2mm needed and I've got a 2, 2.1, 2.26, 2.33, 2.35, and 2.3. I have measured them all several times. Do I round up? I've seen charts for all other iPhone models. But none for the 6 plus. I would pay to download a chart for specific measurements and locations. I just want to get this thing back together to see if I've fixed all my problems! Help please!
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Ahh...the infamous screw chart question; this is the bane of every DIY iPhone tech's existence :>). Apple engineers thought it wise to have pretty much every screw be different from the other. I can imagine them having lulz at the thought of finding new ways to make repairs difficult.
At any rate, there is no easy chart and no one sells them un-jumbled. You need to go through the appropriate guides to find the screw sizes. The truly critical screws are the ones that screw into standoffs on the logic board. If you put a longer one, even 1/10th of a mm, then you can seriously damage the board. The ones that screw into the housing or standoff screws are less critical.
If your caliper is giving you readings that are off by 0.05 mm and repeated zero'ing of the caliper doesn't make it change, I would always err on the side of caution and take one slight shorter, especially for the ones that screw into the board.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
thills7380 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 218
