Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
Preguntas 195 Ver todo
Can I get samsung s6 edge to come out of ODIN MODE?
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key it will turn to a page saying downloading and will stay stuck on this page for hours. I have tried a number of combinations but nothing has worked. I cannot plug into a computer or go into samsung as I am on vacation on an island. I also cannot pull the battery out as I have a s6 edge and if I do unscrew it will void my warranty. Can anyone please help?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 17
Comentarios:
after hard reset my device goes into odin mode and restart what i do
por
I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
por
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
por
whay if i disable usb seeting on my phone then also the reset factory and the laucher of the phone and its system UI shut down automatically ..how can i fix this please help me.. :(
por
maybe my chace is on with ODIN mode but don't how .. please help me lol
por
Mostrar 4 comentarios más
Agregar un comentario
10 Respuestas
Solución Elegida
Press all buttons at the same time and hold them.
Fue útil esta respuesta?
Calificación 111
Comentarios:
Thank you mine was stuck in this mode and I'm fairly new to the android world and this saved my butt majorly!!!
por
love you brother thanx a ton
por
Wow thanks man
por
thanks man, saved me
por
worked for me nice one dude
por
Mostrar 41 comentarios más
Just hold all the Buttons on the same time power button volume up volume down and home button
Calificación 17
get into download mode then hold volume down, power home and the phone should power off. If it won't power back on try holding power and volume down for like 20 sec, it may boot normally.
Boot into recovery power volume up and home and try clearing cache partition (wont delete your files)
then in recovery try factory date reset (will delete your files)
finally if all else fails flash the stock rom (make sure same version or newer than you are using can't go back) using odin
Calificación 7
Comentarios:
THANK YOU SOO MUCH BUDDY !!
You saved my device ! i was worried BADLY ! I was trying to install new firmware on my android ;/ thanks anyways buddy :) God Bless you :)
por
Hold Power + Home 15 seconds (Hard reset)
Hold Voume Up + Power + Home until recovery boots.
If this doesn't boot recovery mode and your phone is stock and untouched take it back to Samsung.
If you've flashed CFW/repaired it you're going to have to put it into download mode (like you were stuck on) and flash OFW via Odin.,
Calificación 5
Thanks a ton. Verified! It Works! Press all the buttons Vol up + Vol Down + Home + Power and hold them!
Calificación 5
Comentarios:
Thank you sir
it s work. do it Valium UP and Down , home , and power key for five seconds . its work. thank god and thank you
por
It worked for me. Thank you so much :)
por
https://www.youtube.com/watch?v=bii27UQY...
Calificación 2
Comentarios:
When I do all 3 it go to maintenance boot mode
por
Try this.
Press and hold together "power button + volume up + volume down + home button" for about 1 minute and your phone will reboot to nomal.
Calificación 2
Comentarios:
When mine reboots it is in another language. How do I change this??
por
Thank you sir
por
Its not working for me
por
Hi, sorry for late reply guys.
Sometimes it takes more time and need to press and hold for about 1 minute.
If this does not work then wait for your battery to drain completely or bring it to your local technician.
por
I yanked the battery out of my Note 2 when it did that. Then opened up Safe Mode by holding volume down as it powered up and removed some files that possibly were corrupt
Calificación 0
Comentarios:
I yanked the battery out of my Note 2 Then restarted my phone in Safe Mode and uninstalled some apps I downloaded from Google Play that had embedded malware and its been ok since.
por
can anybody help me please?
por
i was trying to download iodine apps for my samsung galaxy s6edge plus but i cant download it
por
So sometime this type of situations occurred. Just Install a firmware to your phone. Flash with Odin. But it may reset your phone!!!. After you phone will work properly. Be sure a right firm to your phone. 100% guaranteed. If you have any or queries. Please email me at vineil91@gmail.com. Best of luck... :) :) :)
Calificación 0
Comentarios:
Hi i cant get any of the above to work?help pls
por
I know this board is old, but I'm having this problem but none of these options work. I can get to the blue downloading screen, but when I push the button combinations on that screen it just goes black and does not boot up.
Calificación 0
Comentarios:
So does mine do you know how to fix it?
por
I had to repeat the process a few times before the volume down to restart phone option brought up the black and white Galaxy S6 screen to restart. However, now it keeps looping that screen and not actually rebooting. Keep at it!
por
Hold the power and home button together for 15 seconds
por
Añadir tu respuesta
hajera estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 226
Últimos 7 Días: 1,357
Últimos 30 Días: 6,144
Todo El Tiempo: 117,665
