Where is the fuse for the backlight?
Where is the backlight fuse on the logic board, mbp powers up fine I hear the startup chimes, fan spinning. But the display screen is black. I connect the mbp to an external (monitor) and it works. I need to locate the fuse and test it. Also need the ID number in case it needs to be replace.
Thanks
Update
Ok I check the contracts 38 39 40 all at 0.03. I know that this is bad. I had also found on the lvd connector some kind of white foreign substance together with a bent contact and that is only the beginning of other issues. Iong story short this logic board is going to the trash bin and try to get a new board.
Thank you everyone who gave some of their free time to assit me. Once again thank you and god bless.
Es esta una buena pregunta?
3 comentarios
ramoncastro, in order to help you out it would be beneficial if you could give us the number of your logic board. It should be a 820-XXXX number (possibly 820-2915-A ) and if you add some high res images to your question (front and back) then we could even point it out for you.
- de oldturkey03
What is the history of this laptop? Any liquid spill? When did this happen? Flowing an incident of some sort?
- de Rany
Logic board #661-5852. The problem started when I tear it down(used ifxit guide) to replace the termal paste. No history of any kind of mishap.
- de ramoncastro12
