iPhone 5s screen not sitting flush at the top!
I went ahead and replaced the battery in my Iphone 5S. I must have done something to the screen or there must be something not allowing my screen to sit flush at the top. I think the screen is slightly coming away from the frame and it also doesn't seem to be able to push down into place where you hear that snap. The bottom is fine, just the top. What are my options and what could be causing this. Attached are a few links for pictures. Appreciate any help.
http://i61.tinypic.com/2dl9qf6.jpg
Es esta una buena pregunta?
2 comentarios
I am having a really tough time getting the bottom of the screen up enough where I can wedge something under to lift it up. The suction cup helps, but it also looks to be lifting the rest of the screen away from the frame. Ideas?
- de Craig Pettigrove
I eventually got my problem fixed. I just had to make sure that the top lined up and snapped into place. Then the rest of it fit flush. There is a slight screen separation from the frame, but barely noticeable. Thanks for the great suggestions.
