Repair guides for portable MP3 players. These devices play back stored music from hard drives or flash memory.
Preguntas 7359 Ver todo
My MP3 player won't turn on once I remove the charger.
I can listen to my Sylvania SMP2200 2GB MP3 Player when it is charging, but once it unplug it it stops and the light won't turn on. I know it has to be fully charged to play, but it was charging all night. Any tips?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 11
Agregar un comentario
5 Respuestas
Respuesta Más Útil
I had this problem too its not the battery it must be switched on when charging but plug in your earphones and make sure no music is playing or the battery will be drained and it will result in no charging, That fixed mine hope it helps somebody :p :D
Fue útil esta respuesta?
Calificación 3
Comentarios:
Thanks! That worked for me! :D
por
I don't understand the steps. Can u explain in more detail? Please....
por
It sounds to me like you have a bad battery connection or a dead battery. Remove the back cover from the device. Locate the battery and its connector. DO NOT TOUCH THIS!!! It may be round or boxy. Using a spudger if you have one, otherwise use a pencil eraser, push the battery connector back in. Attempt to turn on the MP3 player. If this does not work, then you may have a dead battery.
Calificación 1
Comentarios:
Do you think this could happen already? I just got it yesterday.
por
same thing happened to me. I haven't even used it yet.
por
Poor quality control (especially if from a "generic" brand) can pass products that don't work.
por
I just got mine.... is YES a generic brand?
por
my Mp3 player just got broken because of you
por
it sounds like its a case of dead(drained completely and cant be re-charged.) battery
Calificación 0
Either try a new charger or get the charging panel replaced.
Calificación 0
You could get a portable charger, if nothing already mentioned worked.
Calificación 0
Añadir tu respuesta
anchorsawaybyjulie78 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 24
Últimos 7 Días: 189
Últimos 30 Días: 813
Todo El Tiempo: 11,528
