The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Preguntas 252 Ver todo
My phone doesn't turn on anymore, I don't know why.
My screen is broken but it was still able to see everything, but one day it just turned off and never turned back on. i bought a new battery and it's not that.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
If you have damaged the screen, you could have possibly damage the LCD with it, try having a new LCD installed on the device and also check to see if your phones On / Off button is working correctly
Regards
Fue útil esta respuesta?
Calificación 0
Comentarios:
How much would it cost to get a new LCD? How do i check if my ON/Off button is working?
por
You can purchase a screen below from iFixit, the link is as follows; Galaxy Note 3 LCD Screen and Digitizer Assembly (T-Mobile/AT&T)
You will have to disassemble the phone and check the flex unit itself, if it clicks and so forth. If there is no click, you will need to clean underneath the silver contact of the button of any dirt that may be under there.
Also make sure your chargers are working and that the battery has at least a little bit of charge inside it.
por
Añadir tu respuesta
Ray Salazar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 322
