Saltar al contenido principal
The Samsung Galaxy Nexus is part of Google's NEXUS lineup of flagship devices. It has an HD Super AMOLED display, curved display, and Android version 4.0 Ice Cream Sandwich.
Preguntas 41 Ver todo
I dropped my phone & now the screen shows black
I dropped the phone while in a rubberized case with a plastic cover, and the screen is now black. The phone still works, but I can't use it because the touch screen is unresponsive & I can't see any of the content. How can I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You may want to disassemble the phone enough to be able to check its connections on the motherboard. It is possible that the displays connection was loosened when it was dropped. Try reseating the display's cable connections and see if this fixes the problem. You may also want to look over the cables and other parts for damage.
If reseating the connections still leaves you with a black screen then may have broken the LCD in the display. To fix this would require a new LCD or new display assembly(LCD ➕ digitizer) if the digitizer is damaged too. The digitizer is the part of the display that is responsible for sensing touch. Hope this is helpful.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
If I wanna fix it myself how much would the LCD digitizer cost for my Samsung J2
- de
Añadir tu respuesta
Hetesh Patel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 1,785
