Saltar al contenido principal
El Acer Aspire 8920 es una serie de computadoras portátiles lanzadas en 2008 por Acer, Inc. Acer es una corporación de electrónica con sede en New Taipei City, Taiwán. El modelo 8920 se lanzó como parte de la serie Gemstone y fue el primer portátil con pantalla de 18,4 pulgadas producido por Acer.
Preguntas 6 Ver todo
laptop resetting during install
can anyone help my laptop keeps switching itself off and restarting during restore even if i use a stand alone windows not restore i have even tried from usb stick windows 7 BUT if iinstall linux or hackintosh its fine installs ok just i even have replaced the hard drive twice does it on windows any ideas
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
i think you forgot boot disk uttulities run over it
- de
Agregar un comentario
4 Respuestas
Hello richardapayne
Sounds like a driver, a memory problem (not to sure why other OS's work though)
Does it restart at the same spot during the installation? If yes what is the installation doing at this time?
I would try running memtest86 for at lease 5 passes (I leave it run all night.)
http://www.memtest86.com/
When in Lunix run psensor to check your CPU temps. When installing Windows the CPU can max out and if the CPU gets to hot the computer will reset or turn off.
http://wpitchoune.net/blog/psensor/
Fue útil esta respuesta?
Puntuación 0
My aspire 8920g restarting with power is on.
In the mode safe works ok.
Puntuación 0
1 comentario:
I had the same problem and after a bit of research I found out that disabling the two cpu cores in the device manager in safe mode solves the problem. Here's the link to the source: How to fix a notebook that freezes when plugged to AC power?
- de
that common in 2008 models. try to update bios. https://www.acer.com/ac/es/ES/content/su...
Puntuación 0
The answer to this Reboot problem is the Capacitor located right under the CPU. Setting the CPU to use only a single core cpnfirms this is correct. There is a repair video on youtube that shows how to do this. The Original capacitor (Single Unit) is peeled off the board and replaced with 4 x 330uf - 2.5v Tantalum capacitors in its place.
It takes patience and care to complete, but is NOT too hard for most enthusiasts.
Whats needed: 2R5TPE330M9 330E 330 330UF 2.5V D SMD tantalum capacitors
Puntuación 0
Añadir tu respuesta
richardapayne estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,122
