The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
Preguntas 75 Ver todo
My blackberry z10 only the red LED lights
my blackberry z10 does not turn you connect the charger and only the red LED turns on and does nothing more. Remove the battery and measures just 2 volts. After charging for more than two hours measured again and the same. according to the specifications of measuring 3.8 volts, if anyone can help me with that
change the software but can not because the PC does not recognize
the model is STL100-3
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
very similar situation:
blackberry z10 have shut down suddenly and will not turn a more. Only the red LED lights up, but makes two flashes every 30 seconds. Replacing the battery gave nothing. If anyone can help me with this.
a computer does not recognize the device in any way.
STL100-1 model
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
If you can not get at least 3.8v out of the battery, then you will need to order a new one. A lot of phones will not power on by the charger alone, a working battery has to be there.
Fue útil esta respuesta?
Calificación 3
Comentarios:
hello sir blackberry z10 charging out 3.8 vol no set dead give soluyion plz help me sir chamandeep.singla@gmail.com
por
I have a bb q10 it's not booting up it just flash red light and displays blackberry and repeat the process and write www.bberror.com/bb10-0020. I have changed the battery still it didn't work,reloaded the os all the same. Pls any help thanks.
Calificación 1
Comentarios:
por
Hi uche ... you should download firmware pangue ..
then (1) open it (2) connect ur device (3) and restart ur device (4)then leave it {green light} till it arrive 100% .. firmeware will close and your device will open auto
por
Añadir tu respuesta
ronyturcios78 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 14
Últimos 7 Días: 65
Últimos 30 Días: 228
Todo El Tiempo: 7,859
