Sony Xperia J, is simply a smartphone that works on Android software.
Preguntas 11 Ver todo
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
3 Respuestas
Do you mean this connector?
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Fue útil esta respuesta?
Calificación 0
The problem that you state.have different problem with mine situation
Calificación 0
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Calificación 0
Añadir tu respuesta
filerzr estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 13
Últimos 30 Días: 56
Todo El Tiempo: 2,601
