Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2189 Ver todo
Error en restauración -48
¿Que puede causar este error, batería, rack de carga? Ayuda por favor
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Tengo el mismo error a mi me paso por restaurar en ios 8.3 con jailbreak si alguien sabe como arreglarlo comente :(
Fue útil esta respuesta?
Puntuación 0
Ola,
ERROR 48 SOLVED!!!!!
Hi,
Updating my 4S to IOS 8.4 was not succesful. Recovery using Itunes gave an Error 48.
Only fools do things over and over again and expect a different outcome.
So there I was being a fool trying recovery after recovery as suddenly I had an idee.
In my opinion there are 3 main factors: the hardware, the software and the test to make sure everything is working properly.
Hardware suddenly broke during update? I don't think so.
Software not OK? Not likely as the same software is already on millions devices.
Test not OK? Probably!
As I noticed being a fool, the Iphone was preparing, installing and testing and just before finishing gave Error 48. So the next time I tried, after the installation was finished and testing was about to end, I simply pulled the connection cord with my macbook and thus with Itunes. Now the testsoftware in Itunes, couldn't tell my Iphone he was not OK and he started just like that and is working properly ever since.
In this case, the patient was sic just because the doctor told him he was.
Maybe, there is something somewhere not 100% Ok, but if I can make calls, read mail, surf the net, use whatever app I tried so far, it is just a perfect working Iphone to me.
Puntuación 0
Añadir tu respuesta
Carlos Chamorro estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 544
