Saltar al contenido principal
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
Preguntas 74 Ver todo
Any way to replace the smooth plastic bezel?
I dropped my lg g4 today and it held up pretty well, it was not from a high height, as I was getting out of my car, and did land on the back but the plastic bezel was dented in two places on one side of the phone. I could just get used to this cosmetic damage and still use the phone, but I was wondering if there was any way to remove the plastic bezel and then replace it.
Es esta una buena pregunta?
Puntuación 11
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Everyone, The sides of the frame are attached to the Glass and LCD Assembly . It is Possible to remove your Display Assembly (Glass,Digitizer,and LCD) from it for replacement but you are able to find the Full Display Assembly with the Frame for about 70 - 80 bucks online. The Frame alone is much harder to find and you run the risk of damaging your display in the removal process. You will thank me by just getting the Full Display Assembly Replaced.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
iantagtow estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 2,954
