The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Preguntas 252 Ver todo
Screen is broke and no backlight. Turns on, and can connect pc
Hello all, I got a free note 3, but the screen is badly damaged
How can I go about testing, or which things can I check to see if they are loose from a drop (looks like that is why it doesnt turn the screen on anymore) I dont see any water damage or anything. She said the screen used to turn on until she took it to tmobile. Could something just be loose to cause no backlight or anything? It fires up, makes the tmobile noise, and I can get to it from my pc.
Any help would be appreciated!
Thanks,
Dan
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
I found an assembly on ebay that says it is certified samsung, for $139, so I might just have to go for that. I was hoping that there may be other things that could cause this, without the entire assembly needing replaced, but that just seems to be what is needed.
Thanks,
por
Agregar un comentario
2 Respuestas
Solución Elegida
Dan Termani, first thing I would suggest is that you replace the display assembly. You really can not properly troubleshoot your phone with the screen as damaged as it appears. It may at one time have turned on, but further circuits in the display may subsequently have failed.
Fue útil esta respuesta?
Calificación 2
Mine is not borken but is a black screen and this was what i found to help. maybe it will work for you?
http://www.blogtechtips.com/2014/12/03/s...
Calificación 1
Comentarios:
Thanks for the link, I actually saw this the other day, but unfortunately did not help any. I was hoping just the glass was cracked, but it seems that I will probably have to replace the whole LCD assembly. : (
por
Añadir tu respuesta
Dan Termani estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 22
Todo El Tiempo: 715
