Saltar al contenido principal
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
Preguntas 180 Ver todo
Big bold vertical white lines after screen replacement
Hey I have a G3 and I recently replaced the screen with the entire frame.. After installing it worked fine. But after five minutes the screen started to show me a bunch of thick white line going from one end to another of the screen. Would you guys have any idea why this is happening ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Bad connection to the daughter board on the bottom of the assembly
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I have the same problem after I dropped the phone, hopefully I just have to check the connections on mine. Thank you very much for this answer, you probably saved me from repurchasing the screen for nothing!
- de
Añadir tu respuesta
blockboy21814 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 764
