Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Earpiece not working after screen replacement
Hi
I replaced the entire screen on my iPhone 6 after i dropped it and cracked the screen. After finishing the installation, i checked to see if everything works.
The camera and proximity sensor works perfectly but the earpiece doesn't work and whenever i make or receive a call, i have to have it on speakerphone in order to hear the other person.
I don't know if its the actual earpiece that is broken or the flex cable is damaged
I have searched the net for answers but can't find any solutions
Any help would be greatly appreciated
Es esta una buena pregunta?
Puntuación 4
1 comentario
I believe the earpiece in the replacement screen I received is defective. Is there a way of requesting a replacement?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Here's a few steps you can try to resolve your issue:
- reseat the earpiece so that the contacts line up.
- check for any visual damage to cable or ear piece.
- if this doesn't work, you may have to try and replace either of the parts.
- also, try cleaning contacts with 99.9% isopropyl alcohol, as oils from your fingers can interfere with things.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
thank you for sharing
i have this problem as well although the phone just dropped
can you please share some pics for better understanding as i have never repaired it before
- de
Try reseating the earpiece. As there are gold connecter on the proximity flex and gold connectors on the earpiece that need to be lined up.
Puntuación 1
I had this issue today, After changing the screen multiple times trying to figure out why I couldn’t get any sound out of the earpiece- I tried reseating the ear piece and figured I just kept installing it wrong I finally cleaned the connectors and the issue was solved! It’s Amazing how sometimes the simplest things is all that matters!
Puntuación 0
Añadir tu respuesta
rkmatthews91 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 17,032
