Saltar al contenido principal
Un teléfono inteligente Android de Samsung para el mercado asiático, conocido por muchos números de modelo, lanzado en diciembre de 2014.
Preguntas 118 Ver todo
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
Es esta una buena pregunta?
Puntuación 21
28 comentarios
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
- de
That was a fantastic clue. works perfect!. Thank You Dude.
- de
Wow that really helped me thank you very much
- de
worked perfectly. thanks much!!!
- de
Amazing advice! Nothing else worked but this did. Thank you :)
- de
Mostrar 23 comentarios más
Agregar un comentario
4 Respuestas
Solución Elegida
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
Fue útil esta respuesta?
Puntuación 33
21 comentarios:
Dat was really helpful. ..thanks!
- de
its working thank you so much
- de
its good idea..... thank u .....
- de
good job...... i really like u......
- de
it's work... thanks
- de
Mostrar 16 comentarios más
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
Puntuación 3
2 comentarios:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
- de
Many, many thanks
- de
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
Puntuación 0
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
Puntuación 0
1 comentario:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
- de
Añadir tu respuesta
Billy495 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 59,886
